Lowering springs
ZeroRain Offline
where would be a good place to look for some springs to drop my 88 TC an inch or two
Drive it like you stole it
1987 Turbo Coupe Auto- gone
1991 Sport 5.0 Auto- gone
1996 LX 5.0 5spd- Gone
1989 Super Coupe 5spd- gone
1984 Turbo Coupe 5spd- newest project
mustangtyy Offline
http://coilsprings.com/
87 TC with 190,000. Gillis valve, K&N on VAM, Home made "Ram" air, Sac Mustang DP to a 3" Dyno Max Super Turbo dumped before rear axle, Ported E6, GN FMIC, RR Cam, T3 at 20 psi.
87 TC with 190,000. Gillis valve, K&N on VAM, Home made "Ram" air, Sac Mustang DP to a 3" Dyno Max Super Turbo dumped before rear axle, Ported E6, Paxton AFPR, GN FMIC, RR Cam, T3 at 20 psi, OBX BOV, Spec Stage III Clutch.
Xr4ti Offline
if the springs from the Xr will work (i dont see why they wont) my friend has some that he never used and is to lazy to put them on if you wanna buy them... i think theyre a 2" drop
Hybridbird Offline
Apparently ,you are not that familiar with the workings of the car you are so fond of.The front of the XR has actual struts(coils mounted right on the shocks)and the rear is an IRS.The T/C's have regular coil springs set up at all four corners, so they are not even close.Just about the only things the XR shares with the Turbo Coupe/Cougar and the Mustang is the engine and engine management,very little else if anything willl swap.Unlike the T/C and the Mustangs, which share a lot of parts...trannys,rears,suspension,brakes,wheels....etc.So long story short,no,they won't work.
"Finch....get the f*ck away from that fikas......that is a jizz-free fikas!"
[This message has been edited by Hybridbird (edited 04-07-2004).]
ZeroRain Offline
HAHAHAHA there is no way the Xr's springs would work that hilarious
Chuck W Offline
Have you EVER even looked at an XR and Tbird..geez....talk about clueless.....
Zerorain...there have been sveral discussions on this subject. Give the ole SEARCH a try....
83 TC Clone, 87 Ranger (soon to be 2.3T), 84 XR7, 80 XR7, 86 XR4 and 62 Mercury Monterey
Eric Offline
Boy, I see xr4t1 is off to a incredible start at these forums. I feel as if I'm watching one of those old films from the German war machine, trying to launch rockets, they go straight up, then come crashing back down in a huge explosion.
Xr4t1, a little advice, use this forum as tool to learn, don't be a tool. Nobody knows more about these 2.3 turbo's then these fine gents. Thanks for the entertainment.;-)
Black 1987 T-Coupe 5 speed, stock xcept for K/N air filter.
ZeroRain Offline
i hope you dont think the Xr will ever be anywhere near as cool and well known as the turbo coupe
Matt S Offline
I got a set 20% stiffer, 1" lower from coilsprings.com. Soft mode is nice, firm is rails.
Sold it Sad*
ZeroRain Offline
matt s what did your bird look like with them on it
