Lowering
cobra_steven Offline
I was just wandering around in Autozone today and I thought i would ask before spending my money on somethin not worth getting....couldn't you just buy some type of Off Brand Drop Block kit as long as it fit for the rear of the TC?? Just thought I'd ask and sorry if it's been asked!!
dadsturbocoupe Offline
Nope. We have coil springs. Lowering blocks are for leaf springs.
87 5-sp, black/red leather. Every option but sunroof.
91 Caprice wagon
66 Mustang convt w/5.0 AOD conversion, 4 wheel discs.
73 Mazda Rx2, 220 H.P ported 13B 74 Chev 1/2 ton p/u completely gone through (cause ya gotta have something to carry parts in!)
71 Datsun 510, race car/street car, father/son project.
2000 BMW 540iT. Beautiful car.
All living in my 40X72X12 shop. Sweet.
Noname
Unregistered
I've heard of these things they sell at Advanced Auto Parts that you put on the spring, it acts like a spring compressor and holds the spring in a compressed state to lower your car. Its the cheapo way to lower you car, and it will ride so shitty you'd probably take them off in a week. Also since they are compressing your spring in a wierd way, I wouldn't doubt they would easily damage your springs.
1988 TurboCoupe - 5 Speed - 115k miles - Fully Loaded except Leather
5"x8" K&N in fenderwell, SVO T3 watercooled .63/.60 A/R, Gillis Valve @ 18 psi, HKS Super Sequential BOV, Walbro 255 HP Fuel Pump, Kirban AFPR, Bob's Big Log Header, 3" DP, No Cat, Dual 2.5" UltraFlos into ATR SS axle/tailpipes, Centerforce Dual Friction Clutch, Pro 5.0 Shifter, Koni Adjustable Struts, KYB Gas-A-Just Rear Shocks and Quads, Custom Progressive Rate 1" Lowering Springs, M.M. C/C Plates, Energy Suspension Parts Everywhere, PST Ball Joints/Tie Rod Ends, Autometer Boost/Vac & Air/Fuel Gauges
87tc Offline
if you want to do it the el cheapo way why dont you just heat um up???
1987tc Offline
On a previous Tbird I cut the stock springs two coils. Lowered it about right and stiffened it up. Didn't kill the spring temper like heating them up does.
Not as good as lowering springs but it does work.
Wes
GaryS#2 Offline
Yep, you can cut a couple rungs safely with a zip wheel on a mini grinder.
Doesn't get too hot and won't hurt spring unless they are progressive wound.
Grocery Getter/Rice Cooker.
Stout85TurboCoupe Offline
How far will cutting two coils off drop the car?
85 TC: Front mount intercooler, pulley, Big VAM, 95 60mm TB, Custom coldair kit, Ported E6, and more
93 GT Mustang with lots of go fast parts: (Stage 3) ported '69 351W heads, ported truck lower and Cartech boxed upper intake, X303 cam, 70mm TB, 77mm MAF, 55# inj., (2) Garret T3/T4 Hybrid turbo's, Custom 30"x18"x3 1/2" intercooler (dual 2 1/2" inlets/single 3"outlet), pulleys, BBK shortie's, Mac O/R h-pipe, dynomax race bullits with flowmaster tailpipes, Tremec 3550 w/ lakewood scatter sheild, centerforce DF clutch, Pro-5.0 shifter, 3.90 gears, SSM liftbars MM sub conn., 15x5 & 15x10 Weld Draglites w/ 315/50 BFG DR's
85 TC: Front mount intercooler, pulley,La3 comp, Big VAM, 95 60mm TB, Custom coldair kit, Ported E6, 3" downpipe into dual 2 1/2" exhuast w/ dynomax race bullits and tailpipes, 87 TC 8.8 w/3.55 gears, RR cam, (soon to come: stage 3 ported 2.3T head w/big valves, T5 swap) and more
DrPhang Offline
I think the best idea for lowering the car so far is the 4banger stang springs up front with some stiff struts...or PRC set to firm, and the Kenny Brown Track Axle Brackets in the back and stock TC springs...
Also maby some 50 series tires?
GaryS#2 Offline
On my car I used shortened V-8 springs in front and Belltech in the rear.
It dropped it about 1.5"-2"
I did measure but forgot the actual #'s
Handling is great and ride is not too harsh, although I want to fix the bump steer that fox bodys suffer from anyway.
