Robert Camp
Jan 2006
Raleigh, NC
I installed a set of M5300-D springs. I like the looks and the ride.
Before, almost empty gas tank;
http://natomessageboard.com/uploads/0000...0_2085.JPG
After, full tank, sorry about the image, it was late in a very overcast day;
http://natomessageboard.com/uploads/0000...0_2086.JPG
Robert Camp
The Shredder
Apr 2007
Charlotte, NC
Yep. Definitely a nicer look! It should handle much better too. It looks as though you have taken very good care of your TC. Nice ride!
88TC blue/blue, auto, loaded except leather, bone stock, 127K mi. - back in the TC game!
88TC white, converted 5 spd, K&N filter, Manual Gillis BV, 189K mi. SOLD :-(
darkthunder
Mar 2005
Walled Lake, MI
Awesome! Glad they worked out well for you. Definitely looks much better too. Now if we can just do something about those ten holes...
darkthunder - 85 TC// 302/C4
2009 Subaru WRX//daily driver
Sorry to be the black sheep,I like it better before.Keep the 10 holes though...
1991 Taurus SHO Plus-Red,black leather.2012 F150 XLT 3.5 EcoBoost.
Robert Camp
Jan 2006
Raleigh, NC
I sort of like the rotary phone wheels too, just wished they were 16" or 17". With 4 lug axles, the only alternatives I've found I like are the Cobra style. Someday maybe a 5 lug swap, then there's some real interesting options. But wheels and tires are a long way off, the tires on the car are practically new Michelins.
Personally, I like the new look and handling. I don't think the original was bad looking or handling, just like the new better.
Bud30Pk, I'm usually the black sheep.
Robert Camp
I like the new look. Nice work.
BigMikeTC
Feb 2004
Dorchester Ma
88TC/86CAPRI
Jun 2007
RUBY,MICHIGAN 48049
I think it looks good, and I would definatly keep the ten-holes on it too.
phil88tbird
May 2007
wichita KS
where did you get the springs at? who makes them?
Robert Camp
Jan 2006
Raleigh, NC
Ford Motorsport. I don't think they are still available, I latched on to a used set in good shape.
The following is information I have collected on springs for the '86 TC. I have no way to absolutely confirm this information, although some of it has appeared in more than one post/web site. So far what I've found is consistent with this information. However, I don't claim this to be the final word, so don't flame me!
Stock Turbo Coupe with
front code 1 is tag TAA that is a 425lb/in with 1750 load rate, code 2 is tag KAC that is 425lb/in with load rate of 1836.
The rear code J with tag JAD that is 200lb/in with 963 load rate, code 3 is tag LUK that is 200lb/in with 912 load rate.
Those were the most popular springs used from 83-86.
Spring set M5300D (for the Thunderbirds) used
the front springs from the M5300B-kit (tag MOG that is 435-530lb/in with load rating 1635) with
tag MIN in the rear with 200-300lb/in and load rate of 732.
The rear springs are production 85-86 Mustang GT Convertible units.
M-5300-D : Tbird
Spring rate Front - 425 lb/in at normal ride height, 530 lb/in at full jounce
Spring Rate Rear - 200 lb/in at normal ride height, 250 lb/in at full jounce
Actual Coil Tags:
Front:
74.5/7275 (Newtons/mm, Newtons; 425 lb/inch, 1635 lbs)
MOG
E5SC-5310-LA
Rear:
35.0/3255 (Newtons/mm, Newtons; 200 lb/inch, 730 lbs)
MIN
E5SC-5560-NA
[It appears that Ford tags specify Newtons/mm and Newtons for the spring rate and load rating. Newtons/mm * 5.71 = lbs/inch; Newtons * 0.2448 = lbs]
Some of the above info indicates that the fronts are progressive rate, but the coils in my possesion have no indication of a progressive winding. However, the rears do appear to be progressive.
Robert Camp
