Lower intake coolant hose.
BabyBlueBird Offline
Might be a dead end question but does anyone know if there are replacement hoses for the lower intake coolant bypass hose. I don’t want to delete it since I do drive the car in colder weather.
John B Offline
Hey, there's a relatively new thread on here that discusses replacement of the coolant lines. Another user listed part numbers on Page 1; https://turbotbird.com/thread-replacemen...lant-hoses
To be perfectly honest, you can use any suitable coolant hose. I replaced mine with regular coolant hose and it's been just fine.
Thank you for the reply. Looks like gates sells a very similar replacement.
firebirdparts Offline
They do, and IIRC, they only list it for the XR4Ti application, which obviously, there aren't very many of those existing. But it's clearly identical to the original T-bird hose.
