Low compression on #1 and #2...
lcdearman Offline
The TC seems to have been down on power lately. I pulled the plugs and #1 was kind of white, the rest looked good. I did a quick compression test.
#1 - 80
#2 - 80
#3 - 120
#4 - 120
That was with all plugs removed. I installed #2 and checked #1 again and got the same result. I guess a leakdown test is the next thing, but I'm guessing it is head gasket time.
Any opinions welcome.
Clay
88 TC - Daily driver, maroon, 5 spd, K&N, pony wheels
81 El Camino - 305/TH350, working on MS TBI/spark conversion
Sounds like it might a blown head gasket, since you have low readings in adjacent cylinders.
lcdearman Offline
I don't have leakdown tester but I do have a compressed air valve holder. I turned the engine until the timing cam bump was on the center mark. I screwed it into #1 and put 25psi on it and I could hear the air coming out of #2.
Guess that means head gasket. Oh well, could be much worse.
lcdearman Offline
By the way, this is the second time the head gasket has blown between 1 & 2. It happened to the PO in 2007, about 80,000 miles ago. The head was surfaced at that time. I guess I should replace the head bolts too since these have already been reused once.
tr_guy79 Offline
Make sure you chase the threads in the block, and use NEW head bolts
3rd Annual Philly Tri-State NATO Meet - http://natomessageboard.com/ultimatebb.p...p=1#000003
'87 - Range Roller 4* adv / 50 trim t04e / Ported E6 / Gutted Knifed intake / Stinger 3->2.5" / Adj. Cam Pulley / Warlboro 255
To Do: PIMP/MS2, FMIC, Bigger Inj
RDOG Offline
While you have the head off, have the injectors tested,cleaned, and flowed, and replace fpr since its cheap insurance.
make sure you have brown top injectors too. I have bought a couple cars with blown head gaskets and they had the wrong injectors.
lcdearman Offline
The head is off, see post http://natomessageboard.com/ultimatebb.p...1;t=024086
Not real obvious like the previous blown gasket...
lcdearman Offline
