Looking for parts and have a few questions
cook96cbra Offline
Most of y'all know I just picked up a nice 85 Turbo Coupe. I'm looking for a few replacement parts and performance parts.
Also, the grey on the bottom is very chalky. Any suggestions as what to use to make it look nice again?
The weather stripping at the bottom of the window, on the outside is cracked. Is that available anywhere?
Looking for any performance parts. Intercoolers, boost controller, exhaust, etc. Let me know if you're selling.
I would like to find a functioning auto dim sensor. It's the big radar detector looking thing in front of the rear view mirror.
Thanks, Matt.
AS I posted on FB, see this article. It is on weather stripping.
http://turbotbird.com/techinfo/83-86_Wea...cement.htm
86 XR7 5spd Offline
the dew wipe replacement discussed in that link is IMO inadequate.
the original 'dew wipes' are integrated with 6 or 7 wire-spring (actually stamped metal) clips which fasten the wipe assembly to the door,
and also a felt pad which guides the window.
by simply removing the OE and replacing with the Universal wipes,
you lose these OE features..
It's a lot more work,
but I'm bisecting the original wipes to keep the clips and window bumper,
then adding the new wipes after notching them to clear the clips and bumper..
gonna be at least 20 pop rivets ..
I'll try to get pix.
David T
T5 / ported E3 / .63 / 35# / K&N
2.5" exhaust w/ cherry bomb
30+ mpg! 8.2 0-60, 16.4@88 1/4 (gTech)
cook96cbra Offline
86 XR7 5spd Wrote:the dew wipe replacement discussed in that link is IMO inadequate.
the original 'dew wipes' are integrated with 6 or 7 wire-spring clips which fasten the wipe assembly to the door,
I like the way you think. Please do post pics and instructions. I would really like to do it right.
Not B Anymore Offline
If the way you are doing this works out well, maybe you could do a write up to put in the tech articles? I'm not sure that the wipes listed in the current tech article are actually still available anyways.
86 XR7 5spd Offline
Wipes are available from rockauto..
Fairchild 1369-4x2 (pkg of 2) "Belt Weatherstrip/ Window Scraper Seal" $29 - discount+ $9 S&H
I got one side done. Big job. Nit Picky...
second side should be 1/2 the time..
Pretty happy with the results altho the window is a bit snug now and is 'shifting' in the track as it goes down,
and the motor is straining on the way up.
I'll get pix on the other side..
David T
cook96cbra Offline
86 XR7 5spd Wrote:Wipes are available from rockauto..
This sounds very interesting. Please do post pics. Thank you!
Silicon spray in the front and rear guides (vertical tracks) may ease the strain in the motor.
cook96cbra Offline
Pete D Wrote:Silicon spray in the front and rear guides (vertical tracks) may ease the strain in the motor.
Good thinking
Puchrider Offline
I saw this on the Mark VII forum, definitely not a factory dew-wipe replacement, but an interesting write-up nonetheless.
http://thelincolnmarkviiclub.org/phpBB3/...&mobile=on
~Puchrider~
1985 BMW 325e
1986 Turbo-Coupe- 3rd Owner
1995 BMW 325is- Daily
1998 "Banana-Yellow" Mark VIII LSC-CE- TR3650 Swap Pending..
2007 "Banana-Yellow" Peterbilt 386- Converting into an RV
