little vacuum thing on passenger fender?
Brandon Offline
I have no idea what it is or what it does, but what is the little thing that mounts up on the passenger fender next to what i assume is a computer. it has two vacuum lines from the turbo that go into it and a plug that goes into it. i dont know what it does or if i need it. when i bought my car, it didnt have one. i bought one from a pick apart and accidentally stepped on it. needless to say, they werent meant to hold 200lbs. haha. any input about it?
1988 Thunderbird Turbo Coupe:
3" exhaust. Cone filter. Stock other than that.
DRADIS Offline
it's not a manual boost control valve is it?
edit: nevermind, didn't see the plug mentioned
1987 Thunderbird Turbo Coupe
Brandon Offline
this is what i was talking about. sorry i couldnt have been any clearer. i honestly didnt know what it was... or what it did. blind leading the blind. what does it do? and do i need one if i dont have one?
Attached Files Image(s)
gadgetolds Offline
Been awhile since Ive seen one but I believe thats the stock boost control valve
Loaded87IROCZ Offline
Hey, I know that towel. That's my picture, lol! Yeah, boost control solenoid. It controls boost by regulating the boost to the wastegate. I would just get an aftermarket boost controller.
Edit: Also, if you need it to get by, you can connect the line to the wastegate directly to boost for about 10 psi or connect the lines from the solenoid together with a blue butt splice for about 13-14 psi.
1986 Mercury Cougar - 5.0 delete mod, 2.3T swap.
Brandon Offline
lol. yeah IROC, it is your picture. i was going through the parts for sale and i saw it and it reminded me that i broke the one i got from a parts yard. it was from a damn near mint condition 1987 Turbo Coupe. everything was in excellent condition. kinda broke my heart when i saw it in there, but got me happy that i could get some parts from it Smile i nabbed my tmic from it. Also, is that a reason on why my boost gauge doesnt work?
Not B Anymore Offline
There is a hose that runs from the vac tree to the boost gauge. It's probably either ruptured or disconnected. Good time for an aftermarket gauge since the factory gauge isn't known for accuracy anyways.
Brandon Offline
that explains so much. a few weeks ago i found a vacuum line that went through the firewall up towards the instrument cluster. it looked like it got cut in half. i couldnt figure out what it went to. solves another mystery. thank you
If it's that cheap plastic line, I recommend you replace the whole thing with new rubber vac line
Brandon Offline
ill have to do that some other time. im gonna have to pull out my driver seat to get up there to see up where the line needs to go
