Hi
Problem with gear selections and shift detents...
When physically in OD, the shift indicator is in the middle of N and OD. The other day I was in Park (or at least thought I was) and the car rolled backwards.
Can anyone tell me the correct way to adjust the linkages so that the detents line up with the physical gear positions in the tranny again?
Thanks!
Thanks!
2.3L Turbo in 88 stang, browntops, 93 a4ld, volvo ic, broncoII rad, gillis valve set @15, k&n af.
