vegas_ss
Jun 2005
Las Vegas, NV
05-17-2023, 10:43 PM
(This post was last modified: 05-17-2023, 10:44 PM by vegas_ss.)
I want to change the lighter wiring from always on to switched on. Main reason is to use a lighter socket voltage readout/USB port charger adapter since the amp gauge was bypassed/disconnected when I did the 3g alternator and I would like to leave the adapter plugged in when the car is shut off. I see there are two wires going to the hot connection on the lighter socket... I assume due to higher current draw/amps needed when using the lighter?
Should I run two 12 gauge 20 amp switched taps from the fuse panel? Can they both run from the same tap/fuse like shown or is one 12 gauge wire sufficient?
Shows the circuit is a 20 amp, probably will never use the lighter but don't want to overload the wiring either.
vegas_ss
Jun 2005
Las Vegas, NV
I'm thinking the two wires are one in, one out for another non-switched accessory like glove box light or fuel door. I'll just run 1 new wire then remove and tape off.
Guess this site has pretty much fizzled out these days? Somewhere else more active? (hopefully not facebook)
88Slowbird
May 2019
Tampa, FL
(05-18-2023, 04:56 PM)vegas_ss Wrote: I'm thinking the two wires are one in, one out for another non-switched accessory like glove box light or fuel door. I'll just run 1 new wire then remove and tape off.
facebook is where everyone is now there's a few turboford and turbo coupe groups
what's wrong with using facebook?
Mach 1 Red 1988 TC: Steeda Tri-Ax shifter, manual boost controller, Stinger FMIC, Boport valve springs, Chip's Ranger R cam, Forge BOV
vegas_ss
Jun 2005
Las Vegas, NV
Thanks...
A lot more "noise" on facebook, info is not as detailed and discussions are harder to locate and follow.
88Slowbird
May 2019
Tampa, FL
(05-18-2023, 05:31 PM)vegas_ss Wrote: Thanks...
sorry for the bad news lol
