Michael Hopper
Nov 2006
Thornton, CO
Can a leaking pws couse pump moter to continuosly run? Also the fluid dosnt leak from under break-moter area.it builds up in the chasie side rail[driver side]And drips under driver side door.I recenntly replaced accumulater;performed all tests in the tech articles article and system all checks out.breaks performing great aslong as their is fluid in system.THANKS MIKE
88
Unless the PWS is leaking fluid at the rate of a quart a minute, the leak itself will not cause the motor to run constantly.
