fordprefect
Nov 2001
Topeka,Ks-United States of America
Not a good combo. Well my dipstick tube has been leaking since I did the HG and I'm just now getting around to trying to get it seated properly. My question is the tube has 2 flanges at the bottom & I can only get it to the first flange (on top of the hole not in it) is this correct? If so what is the other flange for? I intend to put some gasket sealer around the tube after I get it set. What got me motivated was my oil level was low so I put in a little oil. On the drive to my dads (1 mile) it ran like crap, got there checked the oil & it was a little bubbly, Oh S**T. I hope I didn't blow another HG, unemployed right now can't afford to spend the money & need it to find a job.
Thank you in advance for any & all help!
Steven
'88 TC 5 speed 161k White/Red w/leather(air freshener:-)K&N cone,
'74 VW Bug Black/Black Heat in the summer & AC in Winter!
"I Love Deadlines, I Love the Whooshing Sound They Make As They Pass By" DNA
B_Lieder
Jan 2003
Salem, Ohio USA
I put the gasket sealer around mine a year ago when i did my head gasket and pushed the tube back in the hole. Its sealed so far.
Bill L
fordprefect
Nov 2001
Thanks Bill. If your still doin it and have time could you run my VIN? I'll post it at that topic. Again thanks.
Steve
As far as I know it only goes down to the first flange which rests at the top of the hole in the block. Once it is in and the bracket bolted up to the intake manifold bracket, I put the blue goo sealant all around.
fordprefect
Nov 2001
Thanks Pete you always come thru.
Steve
Hurff
Jul 2003
Annapolis,MD
From the .02$ department....
Bubbles, while a facinating diversion outside of the engine really suck inside.
As it appears that these cars are infamous for inaccurate measurement of the oil level with the dipstick (assuming its not seated correctly) you could end up overfilling.
In which case the crank will dip into the oil making bubbles. At this point the oil doesnt really have much in the way of lube properties since it contains a raft of air.
Mine was bolted down, but was located somewhat near the hole.... after my HG I expanded the metal just a bit and have it seated correctly. Still, a normal 5qt change doesnt show as full on the stick.
1987 TC - RIP
