leaking brake switch
OU812MACH1 Offline
Any one know of a replacement switch for the bottom of the master Cylinder ABS system ? Or can I just plug it off ?
o4 mach-1,white,4at 1 of 169 ,MAC air filter and x-pipe, SCT tune / o9 BMW 328 M-SPORT, white, 6at/ 87 Turbocoupe ,white,4at,KIRBAN afr,GILLIS boost valve,Garrett/SVO T3,cold air,3" STINGER down pipe and tail pipe, DYNOMAX ultra flow stainless muffler, Walbro 255L fuel pump,cleaned and flowed injectors,STINGER BOV, built A4LD trans w/all
4x4 Explorer guts, K245/F57FA torque converter.
The switch in the line to the rear brakes has been obsolete for years. I doesnt have anything to do with the brake system it just tells the PRC to switch to firm mode if brake pressure goes over 400 psi.
Someone may have a used one on a car they are parting out, or just plug the hole if your PRC is inop anyway.
OU812MACH1 Offline
Thank you Jeff.....once the turbo install issues are done. Off with the PRC..
