94Lightning
Mar 2003
Springfield, Missouri
Im wanting to switch to a large vam and 35lb injectors in my 86TC auto, can I use the PCM and repin it and use the LB2 PCM from the 88TC auto I parted?
1990 LX drag car
1971 Mach 1
1986 GT conv
1990 Mustang GT conv
1986 Turbocoupe
1988 Turbocoupe
Should work..... Using the stock BCS boost control system, boost will be limited to 9.5 psi, but if you have a MBC, like a Gillis valve, it wont matter. Since the LB series will be looking for the 3-4 shift solenoid and the TCC lockup solenoid and it wont see them, it might turn on the CEL (not sure if it will or not).
94Lightning
Mar 2003
thanks Jeff, my 86 doesnt have a CEL, and I do have a gillis valve. I mainly wanted to do this for the large VAM upgrade
1990 LX drag car
1971 Mach 1
1986 GT conv
1986 Turbocoupe
1988 Turbocoupe
