23027
Aug 2007
South Surrey, British Columbia, Canada
So i'm kind of wondering.. Is there a way to adjust the throttle response? It seems kind of.. Slow. It takes a while before the RPM's start to climb. Not LONG, but compared to like, a Suzuki Swift I have at work it's much slower.
Any way to adjust this?
Remember you have a 2.3 L 4 cylinder engine in a car that weighs well over 3500 lbs with a driver and a full tank of gas. Off boost throttle response will never be that great.... that is what the turbo is for.
Have you checked your ignition timing? Retarded timing will kill tip in throttle response. Might also want to verify cam timing is correct.
23027
Aug 2007
Oh I didn't mean when I was driving..
I meant just idling when I rev the car
Matt S
Mountlake Terrace, WA
Yeah I think tip in throttle response stinks on this car too. My clutch foot is faster than the throttle response when trying to not roll backwards on a steep hill around here, often leading to a stalled car. I've tried fooling with my timing, base idle and all that. It helps a little. IMHO the VAM is the largest problem, I feel it snaps shut for a second on hard throttle making the problem worse. Dunno if I'm right but it sounded good to me !
Sold it  *
23027
Aug 2007
Sooo I got the part about maybe adjusting the timing and base idle..
I don't really get what you're saying though
Matt S
That it stinks  IMHO even after trying some tweaks. It is what it is.
You can't really compare it to a small motor that can be wound up like your Suzuki either. You've got a lot more mass to spin up when you tap the throttle on your tbird.
Sold it  *
ipsd
Jul 2006
Branson MO
I had that sort of problem. I checked my TPS and it had worked loose and had set itself at .78volts. That wasn't any fun. I reset the TPS to .97v and all was well. Also as far as motors go our 2.3t's are a BIG block of 4 bangers!
23027
Aug 2007
This is true..
So how can I go about adjusting my TPS? Where and how would I be able to do this?
Quote:Originally posted by 23027:
This is true..
Try this from the faq:
http://www.turbotbird.com/FAQpage/FAQpag...Adjustment
zip
Dec 2006
Modesto, CA
Here you go
http://www.turbotbird.com/techinfo/Idle-...e2005.html
There is a lot of useful information in the TC Faq and Tech Articles sections. You can find a links at the top of the page.
Matt
