Lacks power on Acceleration
Bcountry44 Offline
Hey guys,
I got a new turbo recently and now for some reason it feels like at around 4500 rpm the car has a governer, like its running on 3 cylinders or something. The turbo spools and boosts so I'm thinking fuel or computer issues. Any ideas on how to trouble shoot this? Thanks
Pull the codes - see the Technical Articles
It might be a sensor issue, doubtful it is the actual computer.
Run the fuel system diagnostics - see the TAs
what kind of spark plug wires are on it?
everyone has a photographic memory. Some, like me, just don't have any film.
Learn from the mistakes of others. Trust me... you can't live long enough to make them all yourself, I've tried!
88 TC, 86 SVO, 04 Escape. Mods list at
Fox ThunderCats Offline
My car lacks power, too. I think it's cuz it's got the lo-po 5.0 'twixt the fenders [Image: biggrin.gif]
Sam's Fox ThunderCats ... Your home on the web for fox Thunderbirds and Cougars
Chad88TC Offline
What happens when you shift to another gear after this happens? Runs real choppy? How much boost you running?
Blue88TC Offline
how'll bout that timing?
88 Turbo Coupe,3"DP,3" Race Pipe,custom Y-pipe,Dynomax Ultra Flows,2.5" ATR SS Tailpipes,K&N filter,Gillis Valve,255 HP Fuel Pump,Kirban AFPR,Ported upper and lower intakes,HKS SSQ BOV,ported e6,t3@17psi,eec tuner. Spec stage 1 clutch,46# injectors awaiting install!
1988 turbo coupe, ported head, big valves, RW #1 cam, adj cam gear, front mount, ported intake, gillis, k&n cone, exhaust
Bcountry44 Offline
I never got a check engine light so I'll go ahead and check for codes anyway. Running stock boost right now. Thanks
B.C.
