hey guys. I have the stock comp in my 85.5 TC...my car came with browntops from factory...and its a 5-speed. i was unsure about the computer...so what is the difference in my current comp and a La3?? (i am not using a big VAM right now) Any thoughts?
thanks!
Zach oh and by the way...fixed that damn problem on my car...turned out to be i had a fitting in my IC pipe that kept coming out under any boost...(hole about the size of a Quarter!!!) plugged it up and the vac lines connected...runs great! finally!
85 Turbocoupe. 5-speed.
Mods- single 2.5 inch exaust with highflow cat and Apex bullit muffler, Saab 9000 front mount IC,Centerforce II clutch kit, Gillis BV set at 19psi,K&N on VAM, Hurst shorthrow shifter.
BEST ET-(1/8)-9.7 @71.9 mph
LA3 programs incorporate the big VAM, brown tops, input from the ACT sensor (only on 87-88s) and inter cooler.
Congrats on solving the problem
is it possible to run a Big VAM with out an La3? and still be a noticeable upgrade?? or would it cause the thing to lean out/run rich??
thanks pete!
Zach
The only cars that had the big VAM are 87-88 TC and all years of SVO. However the 84 -85 SVOs had green tops while the 85.5-86 SVOs had brown tops. The big VAM, big injector PE1 computers are rare and expensive.
Running a small VAM computer with a large VAM is going to cause problems.
Dan E
Greensboro, NC
thanks pete!
Zach
Nope. You need an LA2 or LA3 to run the big VAM I believe. Or what ever the first big VAM EEC was that was used.
Dan Eaves
i feel very enlightened!!! thanks Pete and Dan, you guys are great!!!!!
By the way, this is off this topic but i didnt want to post another thread for something this simple. Dan...you have seen my car...i dont have the front side lamps that alot of the TC's had...yet...i had the brown top injectors from factory. i was guessing at first my car was an 86 because of the brown tops. BUT i ALSO dont have a 3rd brake light either(from what i recall didnt the 86+ have the 3rd brake light AND side clear turn signal lamps??)...i say its an 85.5...is this correct or am i off with this info? Any help appreciated!!
Zach
bigred
Sep 2001
Charlotte,NC USA
Hey man check your E-mail and pms on this site
1988 TC T-5 swap,New Head,Wiseco .030 pistons ,5.5 Crower rods ,balanced ,24x12x3 intercooler,T-3 .60
Ranger Roller Cam,New brown tops.
New 3"cat and 3"single SS exhaust
i dont have any big red... [Image: confused.gif] am i supposed to??
bigred
Sep 2001
Charlotte,NC USA
should have 2 from me Just see your ad in non turbo cars and parts for sale and you AOL adress also
[This message has been edited by bigred (edited 02-19-2003).]
Walsted
Fort Worth, TX
...By the way, this is off this topic but i didnt want to post another thread for something this simple...i dont have the front side lamps that a lot of the TC's had...yet...i had the brown top injectors from factory. i was guessing at first my car was an 86 because of the brown tops. BUT i ALSO dont have a 3rd brake light either(from what i recall didnt the 86+ have the 3rd brake light AND side clear turn signal lamps??)...i say its an 85.5...is this correct or am i off with this info? Any help appreciated!!
Zach
The surest way to determine your model year is to use the VIN decoder in the Tech articles.
The side marker lights were optional on the 85 and 86 years, so that doesn't really help. Third brake light is an 86 requirement.
My january build date 85 XR7 came with brown tops and a PC1 computer. I've heard it thrown around that the early 85s had green tops at first, but haven't actually heard from anyone with an 85 TC or XR7 with green tops.
Hope this helps.
Mike Walsted - NATO member
