I recently had to use the FAQ repair procedure to fix my driver's side window after it dropped off the track. The procedure went well! But as I was begining to reattach the door panel, I noticed my keyless entry system would NOT work. As I began troubleshooting, I noted the following systems/items DID work: All fuses are OK; the door lock switches work fine, the keyless illumination lights are fine; power seats and windows work. It seems that ALL other systems seem to work----but I can't get the keyless entry to work AT ALL. I tried both the original manf code plus my own secondary code. No dice!!!! Before I put the door panel back and have access to the door interior (and keyless pad/wiring) I'd like anyone's suggestions as to what to check next!!! Help!!!!
Gary
