Keyless entry
Noname
Unregistered
How do you clear and then reprogram keyless entry on our cars?
zora_d_1991 Offline
It should be in the manual you hopefully recieved with the car. to clear it you probably just have to disconnect the battery and then reconnect. from what I remember my dad had to reprogram his code whenever the battery had to be disconnected. wish I could help more but my turbo coupe got a different option package than the old mans. gotta use the damn key to get in the car. can you believe that? j/k
"thank you for flying red bird airlines....enjoy the flight."
Hybridbird Offline
I was under the impression that the code was permanent and not re-programable.That's what I was told anyhoo,but I was also informed(maybe mis-informed)that the dealer had a way of retrieving the original code when supplied with the VIN #.......I think....
JT Offline
You're part right. The primary code in the module is permanent from the factory.
However, you can program a second code and that is not permanent.
The primary code is on top of the module, on the deck lid hinge, and in the glove box i believe.
JT
JT
[email protected]
www.geocities.com/turbocpe/
1987 T-Bird Turbo Coupe T-5
1994 T-Bird LX 4.6L
1988 T-Bird Turbo Coupe A4LD
1988 T-Bird 3.8L
1979 T-Bird Heritage 351M
TurboCoupe50 Offline
JT is correct except, if you find the code in the glove box it will be on a plastic card that was meant to be carried in your wallet. Only one of of the 6-7 keyless TC's I had still had it. Found it under the back seat.
JT
Two 1988 Turbo Coupes ..... yea one of em has a 5.0 And runs 13.3s
1988 Turbo Coupe331 AOD
1972 Comet GT
KDice Offline
Enter your code for your car then within 5 seconds press the 1/2 button, then within 5 second enter the 5 digit code you want. to erase this code press the original code i believe press button 1/2 and wait 6 seconds.
Kirk Dice
segfaultxr7 Offline
If you _really_ want to change the permanent keyless entry code, the Taurus module is probably similar or the same, and a SHO guy did a really good write-up on changing it. You'll need to be handy with a soldering iron, though!
<a href="http://webpages.cwia.com/~bdklein/sho.htm">Changing Keyless Entry Code</a>
88 TC 5-speed
