Phillieb
Dec 2010
new york
Hi guys,when I punch in my code on the key pad to unlock the doors the interior lights illuminate but the power locks don't pop up.Even when I press the last 2 buttons to lock the doors nothing happens.When I try locking and unlocking the doors with the interior buttons they work fine.What do you guys think is happening ?thanks Philip
Philip Boccabella Burgundy car 5 speed 1988 Ford Thunderbird Turbo Coupe 2.3 liter. Water/meth system. Recently eliminated the cat converter and added flow master mufflers and 3"pipes.55,000mi./1988 T/C-Black T3 garret new paint in 2018
turbo80sdriver
Nov 2008
Erie, pa
05-30-2016, 07:15 AM
(This post was last modified: 05-30-2016, 07:16 AM by turbo80sdriver.)
Have you disconnected the battery recently? Sounds like your module has failed. You probably already know this, but I'll write it out anyhow - The keyless entry systems light up the interior lights upon any button being pushed. or door handle being raised. There's a module in the trunk's aux tray on the driver's side - these all have a factory code, originally included on a tag in the owner's manual and on the black plastic control module itself. A user can program a custom one, but this gets erased if the battery power is lost to the control module. Normally, even if this occurs, pushing the 7/8 and 9/0 buttons simultaneously will still LOCK the doors even if no custom code has been programmed (by the way, the factory code always works, even if a custom code is programmed). If you've checked fuse #8 good - also powers the clock, key warning, power mirrors, courtesy lamps and chime etc. then I would suspect the module has failed.
'88 TC-Black (TC February 2011)T-5 with 73K
'88 TC-Blue w/93K. Stocker w/t-5. (Feature project 2013)
'88 TC-Grey w/82k. Auto, well optioned, 2nd owner car - getting more options!
'87 TC-Blue w/123k t-5 parts car - less of a car now
'87 GN w/15.5K
