K&N getting wet from being parked
Forcedbird Offline
For all of those who have their K&N filter located just in front of the radiator, or if you have some info on the subject. I was just wondering, when your car is parked and it's raining does your filter get wet from water getting into the small opening between your hood and the grill? On my setup my filter gets wet and when it rains hard it gets soaked with just my car being parked. I am worried that's it's going to damage my filter or even my car. Should I relocate my filter? If I do, does it need to be reoiled (the filter is brand new)? or all that rain is nothing to worry about?
Thanks
88 TC
HY 35, Ported Oval head w/OS valves, EEC Tuner, Bob's MOAL, .510 lift cam, Tial 38mm wastegate, K&N in fender, Kirban AFPR, Walbro 255lph fuel pump, 57 lb inj., GN intercooler, Gillis valve, Race eng. adjustable cam pulley, HKS SSQV BOV, Steeda Tri-ax shifter, 4" DP to 2 1/2" exhaust, no muffers, Timing set to 12* BTDC, 26 psi of boost. Needs to get tuned!
Proud to be a NATO member!
SteveX82 Offline
I had the same exact problem when my filter was routed in front of the radiator, so I decided to just mount it in the fenderwell instead. The oil film on the filter should be resistant to the water, so you shouldn't have to re-oil unless you notice that the water managed to rinse off any of the oil.
Chris Ruhl Offline
If I was you I would move the filter because if your filter is wet, more than likely your engine is going to be sucking in water also.
[email protected] Offline
Banned
well for this problem u gotta think like the imports, get a summit or import mag, and look for an Aem Bypass valve for the intake, you put it on your intake so it wont suck water, sand, what have you, its like 45 bucks and its def a must have if you got a front mount filter, so you can keep it in front of the rad and be ok
~ITaliano~
88 White turbocoupe on Raven,All opitons minus leather/keyless, 5 speed, K&n frount mounted,18psi,White gagues, Custom painted interior trim pieces Gun metal blue,pioneer deh-p8400mp headunit,2 12" subs jbl 1200.2 for both subs RF punch 400x4amp for RF/infinity components,5.6in in dash tv with ps2 behind rear seat arm rest,AM phantom boost,air fuel mustang pod, Saleen pedals, momo floor mats, gray vents, console cover, shift boot, floor mats, visors. Clear corners, with police superwhite strobes, TurboXs type H bov Countless other mods..and many many more to come ..2in cowl, big brakes,5 lug, 18in torq thruts 2s and volvo front mount
