SteveX82
Toms River, New Jersey
I've heard that some of you guys have relocated your k&n's to the cooler area in front of the radiator. What parts did you guys use? I just foolishly wasted about $10 at home depot awhile ago (i didn't think to make sure a 3" tube would fit through that opening in the frame) and am curious as to what other people used. I simply bought a section of pvc tubing, a 90º pvc elbow and a rubber attachment peice to join the VAM to the first peice of PVC tubing.
Kev
Harrison Arkansas
Kev
I used a piece of stiff 3" rubber tubing with a 90 degree angle in it. The 3" will fit through that hole behind the headlight but I had to notch the back of the plastic headlight housing to get it to fit right. I ran it all the way down to the slots in the air dam and zip tied it to the dam. Works great, cold air and it doesn't get wet.
Kev
88 TC 5spd
K&N in front of the radiator, no mufflers, no cat=straight pipes all the way out the duals, bypassed BCS
Car is all black, no red stripe, blackouts, and chrome duals, red leather interior
Mean Fast and Smooth
Kev
1988 TC 5spd
I used about 9" of 3" diameter rubber hose (truck supply shop) from the VAM to the wall opening right behind the headlight.Then I used a piece of 3" diameter, 4 segment heating and cooling tin duct (the segments rotate and the whole thing can be twisted from straight to 90* and any angle inbetween)
from the hose, throught the radiator support wall hole. I put the K&N in from the bottom and clamped it to the tin duct. E-mail me for some pics and write up
Elite Bodega 16" chrome wheels. Autometer pod w/ A/F and Vac/boost gauges. New engine shortly, ported head and
manifolds, polished and cc'd chambers, A-230 cam, Race Engineering Adj Cam Sprocket, Crowlers, ARP head studs, Walbro 190 pump and T-3 for starters. KB subs
and jack rails.
