V6TBird87
Apr 2002
Severn, Md, USA
Last night, i went and picked up an 87 Medium Gray turbo coupe, 5-speed, all options other than moonroof, ATC and keyless entry, the cars paint is rough, clearcoat peeling really bad, but thats to be expected, overall condition is good, paid 500 bucks for it
for the problem, i was bringing it home, drove fine, then started bucking, running rough, spuddering, not wanting to go above 40mph without resistance, i know for a fact it needs a tuneup using Motorcraft parts (has bosch plugs and some cheap wires), and i should check the IC couplers, but is there any thing else to cause it? ive been into thunderbrids for a few years now, but never had an experience with TC's
www.foxthunderbirds.fast-go.com
www.dodge600se.fast-go.com
aka Tbird232ci
2018 Mustang GT
1988 Turbo Coupe, 5-speed
aka Tbird232ci
1owner88TC
May 2003
Wichita, KS, USA
You have the right idea. Do the tuneup first and see how it runs. Look for bad lines. You should probably replace/check your filters to get a good baseline. Scan for codes next. Could be a plugged cat.
fun, fun, fun - Justin
3" DP & Cat, Magnaflos, K&N, Magnecor Race wires, Steeda Tri-Ax, 3-core radiator.
[This message has been edited by 1owner88TC (edited 11-19-2004).]
3" DP & Cat, Magnaflos, K&N, Magnecor Race wires, Steeda Tri-Ax, SPEC Stage 2 clutch, 3-core radiator.
Also get a fuel pressure gauge (if you dont have one already) with a hose lokg enough so you can tape it to the windshield to see pressure while driving. Check pressure to be sure it is spec, especially under boost. If you dont know the specs, let us know, and we will provide them, or do a search.
Do the tuneup, replace the filters including fuel filter and then pull the codes. Let us know if that does it.
V6TBird87
Apr 2002
Severn, Md, USA
most of that is on the list for tomorrow
i know for oil, run mobil 1 synthetic, but what oil filters do you guys prefer? since ive been around turbo dodges, i prefer purolator pure 1's, but i dont know what works best for these cars specifically
aka Tbird232ci
2018 Mustang GT
aka Tbird232ci
V6TBird87
Apr 2002
Severn, Md, USA
i actually read that entire page at one point, very good info
MiniMopar has awesome info, even for the ford guys
aka Tbird232ci
2018 Mustang GT
aka Tbird232ci
servingGod
Feb 2003
Millersport, OH, 43046
Did you happen to notice if it was overheating at all. It might be a clogged cat or muffler, just thought I would through in my two since. I would do the tune up stuff first since you should do that anyway, but if that don't work you may want to look at the exhaust.
88 TC 5-speed maroon, all options, plus t3/t4 hybrid, 255 pump, RR, Centerforce DF with weight fingers, MSD tfi coil.
88 TC 5-speed Black, all options.
88 Thunderbird LX 5.0 All options except Leather.
87TC Parts car five speed all options.
V6TBird87
Apr 2002
Severn, Md, USA
it doesnt show signs of a clogged exhaust, it boosted fine for the most part, it dint bog, didnt overheat, didnt feel like it was struggling, so im assuming its fine...itll get aftermarket exhaust anyways, what self respecting turbo enthusiast could keep stock exhaust [Image: wink.gif]
aka Tbird232ci
2018 Mustang GT
aka Tbird232ci
V6TBird87
Apr 2002
Severn, Md, USA
motorcraft parts are a pain to find locally, have to drive 45 minutes to the closest dealer
aka Tbird232ci
2018 Mustang GT
aka Tbird232ci
