Fellas i think my IVR is going bad?...…….Gauges are erratic and a few times went to zero and then back however...…..does my 88 Turbo Coupe have an IVR and if so why can I not find a aftermarket/replacement for it?
The POS OEM thermal / mechanical IVR is a throwback to the 1960s. Check Ebay, Amazon, etc for a solid state replacement version. I built my own solid state adjustable IVRs for both my Tbirds for $5 each worth of parts.
Usually failing IVR causes the oil, temp and fuel gauges to go to max for a while and then return to normal, but I have seen them drop out too. If all 3 gauges do the same thing at the same time, by far the most likely cause is the IVR.
(11-01-2019, 12:04 PM)Jeff K Wrote: The POS OEM thermal / mechanical IVR is a throwback to the 1960s. Check Ebay, Amazon, etc for a solid state replacement version. I built my own solid state adjustable IVRs for both my Tbirds for $5 each worth of parts.
Thanx Jeff ….can you be more specific as to what I should look for on E-bay on Amazon?.....88 Turbo Coupe replacement SS IVR?..And also is the IVR still on the back of the instrument cluster with the 9v battery type connector?..thanx again
Yup the thing with the 9 V battery connector is the IVR.
I remember seeing some solid state IVRs a year or 2 ago, but dont remember what I searched for, as I wasnt going to buy any anyway since I built my own.
anasazi4st
Feb 2015
Phoenix, AZ
(11-02-2019, 03:05 PM)Jeff K Wrote: Yup the thing with the 9 V battery connector is the IVR.
Jeff:
Can you share with us the schematic and parts you used to build your own?
I replaced mine years ago with a new OEM one, but the gauges are starting to act finicky again—all three read higher with the head/fog lights and a/c on.
andrewjs18
Aug 2012
Philadelphia, PA
(11-04-2019, 08:10 AM)anasazi4st Wrote: (11-02-2019, 03:05 PM)Jeff K Wrote: Yup the thing with the 9 V battery connector is the IVR.
Jeff:
this might be it: https://turbotbird.com/thread-new-design...ivr--35804
Yup, Andrew, that is the article...... I forgot that I wrote that years ago!
anasazi4st
Feb 2015
Phoenix, AZ
11-05-2019, 08:44 AM
(This post was last modified: 11-05-2019, 08:44 AM by anasazi4st.)
(11-04-2019, 12:46 PM)Jeff K Wrote: Yup, Andrew, that is the article...... I forgot that I wrote that years ago! Nice! Thanks to both you and Andrew for that!
