Its actually working
BJL Offline
Moderator
It soem how actually starting to work.
i added a AFPR on thursday set at 39psi at idle, so im running ok, still kinda lean but better.
today i took the "non-working turbo" and intercooelr out of the intake system.
i have a paiced of exhuast tube i bent up going right to the VAM.
with the K&N on there it loud as hell sinc eit has lil to no pick up annoying. but im actually starting to feel a power increase and the im not runnign as lean.
tomorro wi hope to take the turbo cartrige out anf put a piece of sheet metal welded tot he housign so the exhuast doesnt have to run through a seized turbo, hoping agian to get soem more power and fuel efficanicy out of it.
i relaly have nothign to lose doign this.
i average around 11mpg right now. sdo doign this shoudl incrase that at least.
im learnign alot doign this and playign around, so maybe the next TC will actualy be a big motor witht eh help of turbo.
im honestly enjoying a non-turbo car.
and hopfully in the next few weeks i may be aquiring another TC that i wil drive.
and this "butchtered" RTC wil be parted and maybe sold as a rollign shell (its main intentiong when i bought it)
tony if you read this call me to discuss details!
Brian J Larkin
1988 Non-Turbo Turbo Coupe
med gray met. raven/gray interior, fully loaded minus leather and sunroof!
converted to N/A 2.3l by previuos owner, but its a nice driver with working A/C!
remote start, sequentail turn signals, 2003 stang muff. soon to have 3g alt, stereo, k&n, maybe ported intakes and manifold
1988 Turbo Coupe 5spd
gillis boost valve, k&n cone,AFPR, 255lph, HP pump,3G 130amp alt, 3.73 gears,mild torquie cam, factory DP, 2003 mustang take off SS mufflers and custom BJL 2 1/4 tails.
(needs a front frame pull)
Brian J Larkin
88TC 320k miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
Brian, at 11 mpg, you can't be running lean??????
BJL Offline
Moderator
well the timign is set at 10* reatarded, she kinda pings still, i think the "pinging" isnt pinging, but since i have a seized turbo charger on tehre maybe that it?
i dunno im confused, i have the a/f guage taped iright intot he 02 sensor and it shows lean most of the time.
but yea fill it up and i onyl go 250 miles.
its a frankinstien so its all rigged, just trygin to make it work better for now
Brian J Larkin
Brian J Larkin
88TC 320k miles
