Is the gap to small
boosted85 Offline
So I've gapped the plugs at .28 and its still blowing it out at 18psi it never did even at 22psi with the stock computer so is it time for a 6al?
Complete custom downpipe to tail pipe 3in exhaust, ranger cam, cran double valve springs, stock dsm bov switchin out for a good aftermarket, cone filter, fmi 2.5in piping, walbro 342hp, aeromotive fpr, fuel pressure 45 base, 17in cobra R's, steel braided oil feed line, 96lb injectors, megasquirt 1 v2.2, msd blaster 2 coil 86 t3 48, innovative lc1 wideband,
How do you know you have spark blowout? Assuming the stock ignition system is functioning as designed, 18 psi will not result in blow out. I run 24 psi with a .032 gap and have no blow out. I think you have other problems.
Paulie Offline
Banned
++++ 2
I run 25 PSI on my modified engine and 18 PSI on my stock coupe with the factory gap of .034. Personally i do not understand the reasoning for closing the gap. The TFI system produces plenty of spark. Just me could be wrong. I agree with Jeff 100%
bowcephus Offline
Lack of fuel!
NO, it's not for sale........Build your own!
K&N 18psi boost Gillis valve
boosted85 Offline
See thats wat I thought but after we tried the 6al it didn't buck anymore but took it back out cuz it was bad
boosted85 Offline
So now I'm thinking use the distributer as the signal to run a coil pack in batch fire has any one done this I need more spark
jangus Offline
How do you know you need more spark? Have you monitored fuel pressure during a run?
88TC 5speed, 160,000+, ranger roller, Evergreen T3, cone filter, manual boost controller.
One parts car still waiting to be taken apart.
Waiting in the garage: SC throttle body, SC intercooler, graphic equalizer, among other things.
boosted85 Offline
Yes multiple times outs done it since its been squirted and only ran the best after the msd 6al so how do I run dis
What the heck are you talking about? Batch fire is a term used to discuss INJECTOR firing.... injectors are either batch fired or sequentially fired. Are you talkin about a waste spark system? COP? CNP? Do you want to run DIS or EDIS?
I still think you have other problems, not a spark problem as others have said.
84TBirdTurbo42 Offline
i dont think he knows jeff, the car as it has been posted many times before, wasnt running right when it was stock, and now its "modified" and still dont run right. Makes you wonder.. if they posts were a little more clearer and typed a little better we MIGHT be able to help you out a little better dude.
Chris Perry
