jmthunderbirdturbo
Feb 2005
Ostrander, Ohio
my blower fan for my air venst stopped working about a week ago. it was on when i stopped the car, but when i left work and truned the kay back, no workie.... what gives? is there a fuse in the box for just that, because thats all i lost was the blower fan, nothing else went. is this a problem with the little lock switch on the column, or is this a fuse porblem???
thanks for any help in advance.
moller
AM
1987 5.0 sport coupe, intake, exaust.>for sale<
1987 tc, goldie, mods: mandrel bent downpipe to cat with turn down, gillis valve, 155 lph pump, kirban afpr, 100 psi fuel guage, handmade pvc cold air intake, optima. 15.457 @89.22(#24)(special thanks to turbocoupeturbo)(firedoctor)
1988 mazda truck, 431000 mi.
Buisness partner in Aerobird Motorsports.
Did you loose all 4 speeds, or does it just work on high? If it just works on high, likely cause is a blown blower resistor. If it quit on all 4 speeds, check fuse 9, 30 amp. I THINK that the only thing that fuse 9 feeds is the blower. If the fuse is blown it is possible that the blower motor is drawing excessive current due to bad bearings, etc.
Jeff's is correct. The blower is the only thing on fuse 9
trashline
Feb 2005
Levittown, PA
dude did you not read this? it is your own post. and you are basiclly asking the same question.
http://natomessageboard.com/Forum1/HTML/014880.html
fix the ignition switch, I gave you instructions to do it. they are cheap and you can get them from anywhere. and if the blower doesnt work then post the same question twice. in the previous post you said you changed it. But i dont understand why you are asking the same question. If you did change it and your blower fan still doesnt work then Im sorry for being snipy. But you shouldve rephrased your topic title to blower doesnt work .
1966 mustang
1988 tbird
Originally posted by: fordprefect
Mine sounds like twenty crickets on meth!
[This message has been edited by trashline (edited 08-26-2005).]
jmthunderbirdturbo
Feb 2005
Ostrander, Ohio
nah, its ok trash. that was on a different car. this is my goldbird. and this isnt everything in the interior, this is just the blower fan motor. i think ill go check the fuse now. post to follow of results.
moller
AM
trashline
Feb 2005
Levittown, PA
then i am sorry for barking. just wasnt sure what was going on.
1966 mustang
1988 tbird
Nsw
Apr 2004
Vancouver, British Columbia. Canada
Nsw
dont wanna steal your thread but mine only works on high, where is the blower resistor located?
jmthunderbirdturbo
Feb 2005
Ostrander, Ohio
it was the fuse. and no..high didnt work either...it was dead. but its good now. but for how long.....muahahaha!!!
moller
AM
turbocoupes
Jul 2003
Aberdeen,Maryland
Nsw...resistor is behind glove box and to the left... if you have buttons for the trunk and gas door release its almost a straight line from them behind the glove box...has a white connector and the resistor is mounted long ways top to bottom...
Garry McVey "BIRDS OF A FEATHER" Birdoprey always in flight... TBird TC owners are usually wingin' it
TC's 83 project, 86 donor for 83, 86 FUN street car,87 RIP, 87 blue to be stock street car, 87 red donor for blue and others, 87 red daily driver, 88 street and strip HALF WICKED right now, 87 XR4ti project,80 pinto wgn project
Garry McVey "BIRDS OF A FEATHER" TBird TC owners are usually wingin' it
TC's 83 project, 86 donor for 83, 86 FUN street car daily driver with speed equipment from Red 88 donor, 87 blue to be stock street car, 87 red donor for blue and others, 87 red donor, 88 street and strip(now a donor) 14.01 chasin 13.0's, 87 XR4ti project,
