boosted85
Sep 2008
Omaha NE
Ok i have to have the rad fan on all the time and i only have one the passenger side only works. now ill run it hard it will get up to the a and l in norm.a.l right around there and the upper hose is bubbling slightly. also im not running a thermostat. what does this mean?
Complete custom downpipe to tail pipe 3in exhaust, ranger cam, cran double valve springs, stock dsm bov switchin out for a good aftermarket, cone filter, fmi 2.5in piping, walbro 342hp, aeromotive fpr, fuel pressure 45 base, 17in cobra R's, steel braided oil feed line, 96lb injectors, megasquirt 1 v2.2, msd blaster 2 coil 86 t3 48, innovative lc1 wideband,
Blue Oval Bird
May 2010
O'Fallon Illinois
You absolutely have to run a thermostat, no "ifs" "ands" or "buts". Then you to address the non-working fan problem and get everything back to stock.
Next you invest in an aftermarket coolant temp gauge as the factory is about as useful as an "idiot light". Mine always runs at the top of the scale when sitting in traffic, with a thermostat and both fans working.
The "bubbling" in the hose is your coolant boiling. You're on a one way ticket to a cracked head / blown head gasket in the near future.
1988 Turbo Coupe: 5-speed, 75k original one owner garage kept miles.
MODS: K&N filter on the VAM, Gillis Boost Valve @ 16 PSI, Walbro 255 lph pump, Kirban AFPR, Full STINGER 3" turbo back exhaust with Magnaflow muffler, Motorsports 140 MPH Speedometer.
I agree. Also, do you hve the black plastic air dam in place? It will run hot on the highway without it.
boosted85
Sep 2008
Omaha NE
where is the black pastic air dam i dont know where it is. do you have a pic maybe
Redbone
Apr 2009
Ashland, MO
Pete, do you know if an air dam from a regular tbird will work on our cars? Mine is missing and I'd imagine finding a turbo coupe specific part might be hard to find.
All your boost are belong to us
1988 TC 5m 3" elbow back exhaust(with cat and muffler), Walbro 255, gillis mbc, airbox removed w/ K&N cone, A/C removed, Spec clutch, Ranger roller swap.
John A.
zbird
Jul 2008
Joshua, Texas
Redbone, Vinnietbird posted this thread about a replacement option. I saw it in person and it looks great.
http://natomessageboard.com/cgi-bin/ulti...1;t=022687
Also, if you don't want to spend alot on an aftermarket coolant temp guage, just get a Mr. Gasket Thermostat radiator cap. I use one just as a check for my guage which works OK I just don't trust it.
Also you can get one from any similar year Tbird, it will work
