George
Apr 2012
Flora, IL
In my long quest to find a matching turbo that came on my TC, an Airesearch M11, the only one I am able to find doesn't have a center section that is water cooled. The link is here: http://www.ebay.com/itm/Garrett-Turbo-T3...b1&vxp=mtr
Is it okay to go with oil only? Also, is there anywhere online that has a good selection of turbos that bolt right up to TC's? Thanks.
88 TC with reman Airesearch T3 .58ar, Walbro 255, cone filter, Gillis mbc set @ 17psi, Mustang A-pillar pod with vac/boost and a/f, full 3" single exhaust w/ Dynomax ultraflow muffler and header, recirculating BOV custom tapped to factory intercooler
turbospoolin23
Jan 2007
Canada,AB
I personally prefer oil and water but I did run a oil only t3/t4 turbo for a couple years without any issues. When I removed the turbo it was still in great condition and that made it easy to sell.
07-07-2013, 10:36 PM
(This post was last modified: 07-07-2013, 10:37 PM by Pete D.)
That ebay turbo has the wrong exhaust outlet pattern on it. Not sure if that can be changed or not?
The early Ford Air Research turbos were oil only
George
Apr 2012
Flora, IL
I'm kinda leery of going the oil only route but I'm having such a hard time finding one with that two bolt inlet that attaches to the compressor housing and when I do find one it's the non-intercooled style outlet. From what I've researched the water cooled turbos prevent oil from coking inside the turbo. I don't drive my car hard so I don't know if that would be an issue. Anyone know where I can find a good turbo for 500 or less?
Run synthetic oil and let the car idle for a minute or 2 after "spirited driving" and you will be fine without water cooling. If the last few minutes of driving were "normal" (sane) driving, the minute or so cooldown isnt needed.
Dan E
Greensboro, NC
I've got a non-water cooled T3 from an SVO Mustang and haven't had any issues. But like Jeff K. advised, I run synthetic oil and always let it idle for a couple of minutes before shut down.
P.S. Don't forget to block off the water lines if you go the non-water cooled route ! lol
Dan Eaves
Dan S
Jan 2003
Harrisburg, PA
The idling for 2 minutes is to prevent coking of the bearings in the turbo. Coking occurs when the hot oil burns (actually cooks) to the bearing surface due to excess heat and no oil flow (after shutdown). Use of synthetic oil prevents coking on the bearing surfaces, but idling the engine and letting the coolant and the flow of cooler oil to the bearings is good insurance.
George
Apr 2012
Flora, IL
I always run Mobil 1 full synthetic. I just wanted to set my mind at ease, which you all have, if I had to go the oil only route. Pete, if I'm not mistaken that is a five bolt flange with a different exhaust outlet bolted to it, correct? In any case I emailed him to see if he'd send me a pic of the exhaust flange.
I wondered about that but I think there were turbos made that couldn't be adapted. I agree on asking for a pic
turbospoolin23
Jan 2007
Canada,AB
07-08-2013, 06:02 AM
(This post was last modified: 07-08-2013, 06:06 AM by turbospoolin23.)
I agree with letting it idle for a minute or two before shutting down. I use to always do that and that's one of the reasons I prefer oil and water. However I always thought that synthetic oil wasn't good in our engines unless you swap to a roller cam.
