Jackie Reinhart
Mar 2004
Fredericksburg, VA Spotsylvania Co.
They used to work, my rear interior small round map lights don't work, we have replaced the bulbs, and yet they still don't work. Can anyone help?
Also, I wish to install sequential tail lights on my 88 TC, anyone know how I can do that, and where to buy the kit???
Jackie Reinhart
Not B Anymore
Nokesville, VA, USA
I'm gonna guess that the problem is most likely the switch in the console (or a fuse, but I don't remember which one they are on). Try unplugging the connector for the switch and jumping it with the key in run.
Brian (BJL) installed sequential tail lights in at least one of his birds. Try searching - I know he posted something on here a while ago about it.
Check fuse #6
Jackie Reinhart
Mar 2004
I cannot search with out Brians member number, how do I do that?
Jackie Reinhart
cougarman
Mar 2004
Howell Mi USA
^^^^^ +1
The webelectricproducts kit works GREAT!
If you want all 3 (per side) bulbsto flash in sequence, the inner single filament tail light only bulb (I think it is a 194?) must be replaced with a 2 filament tail/stop light bulb (1157/3157). This requires a bulb new socket and some tail light housing mods to get the much larger socket to fit. If you only want the outer 2 bulbs to sequence, the kit only requires some quick and easy wiring.
