interior lights wount shut off
manson Offline
title says it all, tryed the dimmer switch and nothing, maybe a bad door ajar switch?
1988 T-Bird Sport (i would never chop up a tc), HO/T-5 swap,...bunch of other stuff (GOT another TC!)
1987 turbo coupe 5speed, silver with red interior.
My CarDomain
1988 T-Bird Sport and 90 SC
Door ajar and dome light door switches are not the same switch! Door ajar switch is attached to the latch mechanism inside the door. Dome light switch is on the frame of the car by the door hinges. It pushes in to turn off. See if both switches (one for each door) are working...... not stuck, bent, etc.
Also, discinnect the connector from the main light switch (with both doors shut). If lights go off with switch disconneced, light switch is bad.
88 Turbo Coupe: Intake and exhaust mods, T3 turbo at 23 psi, forced air intercooler, water injection, bypass valve, Ranger roller cam, subframes, etc., etc.. // 86 Tbird 5.0 (original owner): intake, exhaust, valvetrain mods, 100 HP nitrous, ignition, gears, suspension, etc., etc.... // 91 Escort: Bone stock winter car // 04 Taurus Duratec (wifes car)
[This message has been edited by Jeff K (edited 06-16-2005).]
William Waters Offline
also check at the back of center council there is a switcth to turn the lights off and on
JT Offline
The switch on the back of the console controls the two dome lights for the rear seat. They don't control the center dome light, or the lights under the instrument panel and door panels.
Do you have the keyless entry system?
