intercooler hoses keep splitting!!!!
BJL Offline
Moderator
Ok isplit the second turbo to intercooler hose last nioght, and well its pssing me off cuz i dont have any other spare hoses and no one aroudn here even has a hose that size!
am i doing somethign wrong? i mena i was on the highway doing around 75-80 and noticewd i could only get 5psi at 3500rpm, well i limped it home and look under the hood and my pvc valve was poped off, and one of the vacuam lines to the intercooler was off, and both intercooler hoses were bulging.
whats goin on!!!!!!!!! im running uregulated boost, but shouldnt these be able to hold more boost?? agh i will be posting about finding one asap HELP!!!!!!!!!
Brian
1988 Turbo Coupe 5spd, dark blue
http://crazydriver358.5u.com
Brian J Larkin
88TC 320k miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
Are you using new or old hoses - both Vacuum and IC? Old vacuum hose dry out and enlarge over the ports they connect to. And if your running unregulated boost, each end of every hose that sees boost should be clamped somehow. This also applies to the PCV valve - both ends. You can get new IC hoses from Tiny Avenger - see link on Vendor's page.
Go to the local hardware store plumbing dept, and get some rubber PVC pipe couplers for about $2 each. The coupler for 2" ID PVC pipe is a perfect fit for the IC to TB hose, and the coupler for 1 1/2" ID PVC pipe is a perfect fit for the turbo to IC hose. You will need to cut an inch or so off one end to shorten them a bit. They will work until you can get some offical replacement silicone hoses, or just leave them on for good. I have had a set of these on my TC for the last 6 months after I split a hose, and they still seem as good as new. I do carry a spare set in the truck, though, so i can pop a new one on if one blows while I am out on the road.
Dan E Offline
Do you have your I/C bracket still installed ? Maybe excess vibration ???
Dan Eaves
Dan Eaves
BJL Offline
Moderator
I have the bracket ont here butr i noticed one of the bolts missing. i think the inside is stripped out, and on my spare its stripped out too.
I CDusoin that works at ford checked up on the hoses at the foprd d34alership to dya and they are sdisocntinued!, argh! i need these quick!
Jeff: when i check the hoses it measures innner diameter 2 1/4 inch by 4 inches long?? is that right??
im going to Home Depot and Lowes right after school to get the sizes you siad, i need this fixed, HOME COMING IS TONIGHT!
Thanks Guys ill be order from tiny avenger next week
Brian
Brian J Larkin
88TC 320k miles
BJL Offline
Moderator
Brian
Brian J Larkin
88TC 320k miles
