intercooler finder
Noname
Guest
how do i go about getting an isuzu npr intercooler. what might be a good sight to find one. would the volvo 740 work as good
Kev Offline
Any intercooler that has more surface area than the stock intercooler and still has good flow characteristics is a good upgrade for the TC. The trouble is getting everything to fit and hooked up in front of the radiator.
Kev
Kev
1988 TC 5spd
Glenn 88TC Offline
The Isuzu NPR will work better. It had to cool a bigger engine with mo=re boost in it's original application. The Volvo works well but it was on an engine the same size as ours. The NPR was cooling a diesel truck which has much higher boost and air flow.
Check on ebay. I have seen them pop up once in a while. Post in the wanted section of turboford. One of the junk yard guys will find one. They aren't cheap.
Glenn 88TC
current mods: ported & polished big valve head(1.89/1.59), ranger roller, custom upper and ported lower intakes, t3/t4 turbo, powerstroke intercooler mounted full sized, 60mm throttle body, 42lb. injectors, MSD 6al, MSD Launch Control, K&N filter, Walboro 255 pump, Kirban adj. fuel reg., ATR header, full 3" exhaust with Dynomax Ultraflow muffler, Star stage III clutch, Tiny Avenger bleed valve, Weld Draglites with M/T ET Street 26x11.5/15
Upgrades coming very soon: Hallman boost controller, rebuilt trac-loc, S&R Racing driveshaft loop, big roller cam, SDS Injection
NO TC and NO headaches.
RDOG Offline
They aren't cheap. Evilbay averages $300 for these IC's. I paid $200 for mine. If you can check the local big truck yards. The Izusu NPR, GMC diesel 4 banger, and Chevy all carry this IC. If I were you I would go on evilbay and print up a pic with the specs and go to the local junk yards and ask if they have one. Makes it simple. Also if they dont have oine, they can get on their CB and ask for you. Thats is what they did for me. Good Luck.
GT350R Offline
Just gotta look. I found three in 2 weeks for 30 bucks each [Image: biggrin.gif]
No none are for sale, I still need more [Image: wink.gif]
GT350R
84 Gt350 2.3T T-top
84 Turbo GT 418rwhp
My Garage
Glenn 88TC Offline
Keep an eye on this, http://ubb.turboford.org/ultimatebb.php?...3;t=002171 maybe you can get one here.
Glenn 88TC
