Blue88TC
Jan 2003
Glen Burnie, MD
ok what wire is the signal wire that i tap into on my o2 sensor? coming from the o2 sensor is 3 wires, 2 whites on top and a black on bottom, i think its the black but not positive, which is it and how exactly do i tap or splice into it. thanks!
1988 turbo coupe, ported head, big valves, RW #1 cam, adj cam gear, front mount, ported intake, gillis, k&n cone, exhaust
Blue88TC
Jan 2003
Glen Burnie, MD
yes thats what i thought...its the black coming out of the o2 sensor right...now how exactly do i tap or splice into that wire to hook up the purple wire from the a/f gauge?
88 Turbo Coupe,3"DP,3" Race Pipe,custom Y-pipe,Dynomax Ultra Flows,2.5" ATR SS Tailpipes,K&N filter,Gillis Valve,255 HP Fuel Pump,Kirban AFPR,HKS SSQ BOV.Ported Intakes,Ported E6,Volvo front mount,T3/T4 awaiting install!
I'd splice into it on the harness side of the connector - so if you change the 02, you don't have to rewire. Soldier the connection ands wrap it.
You only need two tools in life; WD-40 and Duct tape. If it doesn't move and it should use WD-40. If it moves and it shouldn't, use Duct Tape.
Artificial intelligence is no match for natural stupidity.
philS
Bellingham, MA
Sorry to hijack, but I have a related A/F question.
On pre-87 cars without the heated 0<sub>2</sub> sensor, any idea how long before the A/F should register a reading? Does it wait until the exhaust reaches 600°F?
86 TC, 73 Mini, 72 Mini Van project (w/ LS-1 motor)
Click here to beat a ricer.
