powered by turbo
Apr 2003
Boise, ID
I was driving home from work today, cruising down the highway and the car died. I ran all the checks I could on the side of the road. Everything seemed good to go except the pump wasn't running. I checked the inertia switch and it had indeed cut the power to the fuel pump. I reset the switch and it is working fine now. The weird thing is that I didn't even hit a bump, I was just cruising.
Has anyone ever seen this, and is this a sign that this thing is going bad? I'm assuming that if they are bad this part is discontinued from ford? Or is this same switch in use in a lot of cars?
1986 Mustang SVO
Ralph H.
May 2006
poughkeepsie,N.Y.
Same as other fords,get a mustang one.Its just a switch wired inline.I've never seen one go bad.With the car running,wiggle the wires one at a time,if car dies the wire going into connector is bad or loose.good luck!long live boost!
DonH
Jun 2002
Central Massachusetts, USA
Inertia switches go bad all the time from internal rust causing intermittent problems that are difficult to track down. You are lucky finding the problem so easily.
1987 TC stock except ATR 2.5"
Don is correct... not only internal rust, but on TCs, the switch carries the full fuel pump current instead of just the 100 mA or so FP relay current as in most other Fords. Good chance you will find the electrical connector nearly melted off the switch.
charles88tc
Nov 2004
dahlonega ga us
Had the same problem in mine also. My dumba$$ replaced the fuel pump, and after that no start. Ended up the pump was good (both of them ) just the inertia switch.
