red coupe
May 2003
rockville centre,NY,USA
Hi:
I have an 87 turbo coupe with auto trans. Its needs a turbo and i have found one that is for a manual trans car. Will it work and if so, what mods are necessary to make it work correctly.
Glenn 88TC
Lebanon, PA
The turbos are the same from auto to manual cars.
88TC
current mods: ported & polished big valve head(1.89/1.59), ranger roller, custom upper and ported lower intakes, t3/t4 turbo, powerstroke intercooler mounted full size, 60mm throttle body, R.C. Engineering 42lb. injectors, MSD 6al, MSD Launch Control, MSD 8.5mm wires, K&N filter, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, full 3" exhaust with Dynomax Ultraflow muffler, Star stage III clutch, Hallman boost controller, Flex-a-lite adj. temp switch for stock fans, Weld Draglites with M/T ET Street 26x11.5/15
Coming very soon(ordered and on the way) SDS, 73pph injectors, custom roller cam
NO TC and NO headaches.
