IHI turbo feed gasket ?
ianbfromct Offline
I've got a nice little oil leak from the oil feed line on the bottom of my IHI. What do you guys recommend for a gasket ?
88 5 speed TC
kunar Offline
the line on the bottom is the drain, and you can get the gasket at an auto parts place. not sure if you can git it alone, but the kit is like $8-10 iirc
1987 Turbo Coupe
1987 Ranger 4.0, 4x4
1991 Escort GT
ianbfromct Offline
kunar Wrote:the line on the bottom is the drain, and you can get the gasket at an auto parts place. not sure if you can git it alone, but the kit is like $8-10 iirc
Ah okay I didnt realize that thanks..im gonna try to find the kit tomorrow. Should I be using silicone on the gasket?
88 5 speed TC
These are the P/Ns: http://natomessageboard.com/ubbthreads.p...Post224414
No Silicone sealant. Install the gasket dry.
