Hey everyone, I'm a beginner,so this may sound stupid, My turbo when't out and I have A 88 tc straight drive my ? is will a turbo off a automatic trans work on a straight drive? the ford dealer says its different part numbers . Can u help me. Ive found one off of a auto with only 52000 miles on it . thanks Kent [Image: confused.gif]
I know of no reason why it won't work.
manifolds, polished and cc'd chambers RR, Crowler, ARP head studs, Walbro 190 pump and T-3 for starters. KB subs
and jack rails
1987tc
Bicknell Indiana USA
What the dealer doesn't realize is that just because it has a different part number doesn't mean it won't work! Look at all the T3s and ranger rollor cams people are using on this board!
Wes
1987 TC:
HUrst compition plus shifter,K&N cone,rollor cam,custom single exhaust,H&R springs,KYB shocks,struts and quads.
3.73 rear. lots more to come!
Linton Indiana
Matt S
Mountlake Terrace, WA
I remember seeing a post on the old board about having to drill out the metal bypass tube outlets on an auto turbo, as it's restricted to save the trans. I could very well be mistaken, though. Anyone else?
Sold it *
1987tc
My parts car is an auto and my driver is a 5 speed. No difference between the two that I can see. As a matter of fact now that I think about it my 87s turbo came off of another auto parts car. I can hit 18 psi no problem! And I still have the original turbo and it looks like the other two.
Wes
1987 TC:
Linton Indiana
You can use the IHI Auto, its easy but Take the T fitting off your current turbo(compressor housing with one line going to BCS and other to turbo), and screw it into the auto compressor housing, otherwise your BCS system wont work the same.
88 TC Auto, 3" exhaust, with 3" flowmaster. with KN cone(5 days), gillis boost, Air water IC (comming soon) and a t5 swap,
1987tc
Does anyone still use the bcs? I thought everyone was a gillis follower...... [Image: biggrin.gif]
1987 TC:
Hurst compition plus shifter,K&N cone,rollor cam,custom single exhaust,Gillis valve,H&R springs,KYB shocks,struts and quads.
Linton Indiana
1987TC,
Well, yeah, sort of, maybe, I guess so. My daily driver is still using the BCS, but only because I haven't had time to put in the Ric valve I have had for it for 2 months [Image: biggrin.gif]
manifolds, polished and cc'd chambers, RR, Crowler, ARP head studs, Walbro 190 pump and T-3 for starters. KB subs
and jack rails
