Craig
Jul 2008
Jonesville, MI
Hi! I have a 88 TC that I needed to replace the distributor and I lost the paper where I had the layout of the #1 plug. Is there a wright up on how to replace the distributor and set the ignition timing?
Thanks
YEAH!!
Ryan H
Oct 2004
Panama City, FL
Welcome to the forum.
You can check the FAQ's and search the forums to find the info you need, it has been covered many times. At this point, I would reset the timing completely if you've had the distibutor out for a while.
The #1 plug is closest to the upper to lower intake bolt nearest the driver's side fender.
firstsvo
Mar 2004
miller place, ny usa
Look at the faq's or the tech articles on how to change the timing belt. Gives you all the info on how to time everything up. Very easy.
thumper
Jun 2001
Dexter, MO
Here it is. http://www.turbotbird.com/techinfo/CamTi...t%20Up.htm
You should check out the FAQ and the Tech Article page and read em all. You'll spend hours there!!!
...at least I did.. :o
A.K.A. Corey Bennett
Garrett
Mar 2008
Cypress, California
the search function is your best friend!
88 TC Black/Black Interior, Auto, 2.5" Exhaust w/ Flowmaster, K&N w/ Custom CAI, New Paint, Kicker Sound System, Limo Tint, Smoked Head/Tail Lights, Tripminder, Cobra R
