I just picked up an 84 svo(blew up the tc last year), the ignition switch is screwing up, I got into it - what are these bolts(?)? I was expecting to find torx bolts with the center pin, but these are stepped and smooth! What do I do - grind a slot for a standard screwdriver to get 'em out
Steve Wagner
Nato member
87TC auto(stock)
88TC, 5 speed, StageII Star clutch w/ StageIII pressure plate,lightened flywheel, K&N in fender, gillis valve, 255lph Walbro, Kirban adj.FPR,Bypass valve, 3" exhaust from turbo to tip (high flow cat/ Magnaflow muffler), A-pillar gauges(A/F & Boost), 16" ARE 5 spoke wheels 7" front 8" rear(225/50VR16 / 245/50VR16 Yokos'). Subframe connectors
Steve Wagner
Nato member
87TC auto(stock)
Steve Wagner
Nato member
84 SVO
Nato member
84 SVO
