Ignition Switch Failure FYI
Nitro_X Offline
I had been experiencing several weird electrical glitches lately. Oil, temp & fuel level gauges reading very low, speedo and tach jumping around, car would die and come back on while driving down the road, idle speed going high then mysteriously settling back out at 1k RPM.
I pulled the steering column shroud and found the ignition switch about to come apart! The four metal tabs that hold the connector / contact block to the switch body were never properly crimped down. The connector block was hanging down enough that upon removal and disassembly, I found the detente ball for the sliding contacts gone! I replaced the ball, cleaned, deoxed and regreased the switch internals. Then I recrimped the four tabs with a small riveting hammer. Everything seems to be back to normal now. Just thought everyone might like to know......
87 TC, T-5 swap, billet quadrant / adj. cable, solid state IVR, fog light relay mod, PST suspension, KYB-AGX fronts, Gas-A-Just rears, K&N, bypassed BCS, med. red, 90's wing, 181K+ Mi's., daily driver, feeding on ricers!
87 TC, T-5 swap, billet quadrant / adj. cable, solid state IVR, fog light relay mod, PST suspension, KYB-AGX fronts, Gas-A-Just rears, K&N cone, billet alum BCV, med. red, 90's wing, polished snowflakes and centers, 195K+ Mi's., daily driver, feeding on ricers!
84Bird Offline
Replace the switch, Many Fords (and Houses) have burned to the ground. Recall went back to 88, bad switches back to 83-84. Ford saved money at your risk. Cheap at $20 or so. Mark
They fail so often, I carry a spare in the trunk.
88TCSEYMORE Offline
Thanks for the info on the ignition switch!! I have had some problems with my radio cutting out when turning the steeing wheel on my 85 tc.After reading this thread i went out and pulled the column covers and found my switch is coming apart!!!I guess i need to replace it asap!!!
88TCSEYMORE Offline
One quick question on the ignition switch removal i have!!How do i remove the rivit looking fasteners????????? Let me know!!Thanks!!!
Slot the fastners with a dremel and it's cutting wheel and use a regular screw driver to remove and reinstall. Dremel rocks [Image: biggrin.gif]
88TCSEYMORE Offline
Pete--Will the fasteners just unscrew after there notched??Let me know!!
Quote:-Will the fasteners just unscrew after there notched??Let me know!!
Unless there have been significant changes to the way a spiral inclined angle works, yeah they just unscrew. Just slot the head like a regular screw.
88TCSEYMORE Offline
Ha Ha--Thanks Pete!!
mmedic50 Offline
Those are safty torx screws. You can get a set of bits for about $4.00 at Advance Auto or Auto Zone.
1988 TC 5 speed, Dark Blue
Build date 5/88.
140 mph Ford Motorsport Speedometer
Tripminder
Walbro 255 Fuel Pump
Kirban Adj. Fuel Pressure Regulator
K&N Air Filter
Gillis Boost Control Valve
New rebuild- .030 over pistons.
SS valves(1.89/1.59).
Center Force Stage II clutch.
ARP head studs.
Crane roller cam .450 lift.
Gutted upper and ported lower intake.
Ceramic coated and ported E6 exhaust.
