Gary F
Jan 2004
Lakewood, California USA
I know this subject has been beaten to death, but I just want to throw in my .02. A few people have described certain symptoms that indicated a bad switch, and I have been dealing with those same symptoms off and on for almost a year. It got really bad the other night, so I decided it was time to R&R the switch. Took off the cover, dremelled the screws, removed the unit. It disintegrated right in my hand. It was barbecued. I thank God that it didn't cause a fire. I replaced it with a $15 part and now everything is fine. Fifteen dollars well spent not to see my TC cremated. I'm just saying that as soon as you notice the symptoms, fix it immediately. BTW, don't accidentally drop your Dremel on your seat when it's on. One more thing....exhaust manifold gaskets, or not? I'm preparing to drop the engine in probably next week.
Gary Fraser
'88 T5 Bone Stock w/3G Alt.
Golden Bird
Jun 2006
Hanover PA.
I had A 88 now I have A 87 both has ignition switch replacements,the 88 I replaced twice. As far as I know these cars had recalls notices for that ignition switch meltdown problem. goldenbird
tiny4lx
Feb 2005
Nottingham,Pa
What symtoms did you have? I have to replace mine, i noticed when i had to repin for the new connectors that this switch was burnt bad on the inside[where the pins are]
Where and what part# did you get?
Its a 2.3 until you hear the whistle
Gary F
Jan 2004
Don't remember and I don't have it handy. I just went to Autozone and picked one up. The symptoms were that upon startup the gauges and the climate control were dead and the brake lights wouldn't go out. I would just wiggle the key until everything started working. It was only happening off and on until the last couple of weeks when it would happen every time. The other night I couldn't keep the car running. Time was up.
Gary Fraser
ScottT80
Aug 2006
Upstate, South Carolina
I just put one in mine... went with a Borg Warner switch from O'Reilly's for $12. I bought a cheaper switch, got it home and went to put it on and discovered it was already broke. Glad I replaced it... heard too many bad stories about them going bad. It did cure all of my ignition issues with my car as far as having to jiggle the key to get it to start and things of that nature.
