georgechard
Mar 2003
villa rica ga usa
has anyone had a problem with the switch in the steering column melting? I know it's a recall thing with Ford but their fix does not work. So is their a way to run a relay for the wires that melt? (make the switch have lower amps and the relay with the load.)
DonH
Jun 2002
Central Massachusetts, USA
Sure, you could do it, but it's probably more trouble than it's worth. Ford's original switch was marginal in its capacity and over time dirty contacts in the switch raise resistance that causes the overheating. There are plenty of posts on this forum talking about the problem. Most people just install a new switch from a quality supplier like NAPA, repair or replace the connector, and the problem goes away. With the relay idea you would have to switch the two power wires into three separate circuits, START, RUN, and ACCESSORY probably using three relays, one normally open SPST for start, one SPDT for RUN (normally closed) and ACCESSORY (normally open) , and one SPST (normally open) for power to the other relays, each relay switched by the positions on the ignition switch.
1987 TC stock except ATR 2.5"
georgechard
Mar 2003
villa rica ga usa
Thank you, That is alot of work so I think I'll hold off for now. Is the Napa brand switch better than Fords? Thanks again....
DonH
Jun 2002
They should be equal. Ford changed the switch after all the fires.
georgechard
Mar 2003
villa rica ga usa
I HAVE PUT THE NEW ONE IN AND IT STILL MELTS.sorry for the caps.
Then the switch itself is probably not the problem.
Maybe there is a short in the wiring or connector.
georgechard
Mar 2003
villa rica ga usa
I guess It's possible but this is the same problem that I had with another turbo coupe.They both have had the same thing happen,They get hot and melt over time when I run the a/c on long trips.And it's worse if I also have the lights on.It melts where the switch and the wires conect together and burns out the switch.
Footintim
Jun 2007
Marcellus, NY
I agree with Pete D. also check all of your grounds wires.
georgechard
Mar 2003
villa rica ga usa
THANKS AGAIN FOR ALL YOUR HELP!!!!!!!!!!
