BabyBlueBird
Jun 2021
Havre De Grace Maryland
Does anyone know if the single wire that runs off the ignition lock cylinder is able to be replaced? Mine as turned to dust. I cant really find anything on it, its a single black/ purple wire that clips onto the lock cylinder.
vegas_ss
Jun 2005
Las Vegas, NV
I'm pretty sure that wire is only for the chime when the key is in the cylinder and the driver's door is opened... Nothing too critical unless you are forgetful
BabyBlueBird
Jun 2021
(07-09-2023, 05:06 PM)vegas_ss Wrote: I'm pretty sure that wire is only for the chime when the key is in the cylinder and the driver's door is opened... Nothing too critical unless you are forgetful
Thanks for the info. Won’t be using it anymore unless I can make something work.
anasazi4st
Feb 2015
Phoenix, AZ
(07-09-2023, 09:29 PM)BabyBlueBird Wrote: (07-09-2023, 05:06 PM)vegas_ss Wrote: I'm pretty sure that wire is only for the chime when the key is in the cylinder and the driver's door is opened... Nothing too critical unless you are forgetful
Mine worked so infrequently it was annoying, so I disconnected it for good. It does nothing else but what vegas suggested.
