Idle problem only when cold
Metal381 Offline
Hi i have an 87 t bird. My problem is a wierd one. Anythime the car su=its overnight or for awhile enough to cool down i have an erratic idle problem. The problem will start after the car has been on for a few seconds. The idle will jump up and down from 500 to 1500 and sometimes stall. The other problem that occurs at this time is if i try to hold the rpms to say 3 grand it sputters through the rpms like its missing. After about two minutes the problem totally disappears and the car drives great. I can rev it to 5 grand no problems. I am stumped.
to date here are things that have been changedto fix this problem
1) new vam meter
2) new coil
3) plugs and wires, cap and rotor
4) IAC
5)Computer
6) tfi module and pickup
I dont understand how it comes when the car is cold then leaves completely.Any advice would be greatly appreciated
With the engine warmeds up, pull the codes.
BJL Offline
Moderator
i suffered through this problem 2 years ago,
i finally changed my TFI and PIP with FORD MOTORCRAFT parts and it has never come back, i stil have the module and i put it in my parts car and started the car up and it did it, so its that bad module,
its a common thing with this. i thought my car was cursed for a while, try another moduel but make sure its a ford part. brnad new not remanufactured.
these TC's are sensitive and need Ford parts for igniton or EEC-IV computer related stuff to be Ford
Brian J Larkin AKA Turbo
1988 Turbo Coupe 5spd
Twilight Blue
boost valve, k&n cone, glasspacks gettto rigged ram air, cracked header panel
[Image: burnout3-9.jpg]
[This message has been edited by BJL (edited 04-22-2003).]
Brian Larkin
88TC 330,000 miles
Slightly Modified
revamp Offline
How much does a new TFI and PIP cost all together by the way? All this talk about needing one makes me curious....
88 TC W/ 87K:
K&N in custom sanded airbox||Gillis Valve||Stereo Sytem: Pioneer 8400, Infinity Ref. Series & Polk Audio Speakers Powered by 4 Channel Pioneer Amps||Performance Radiator & Cooling System||Custom Interior Converion||Gutted Cat & Dynamax Ultra Flow Muffler||Indiglo Gauges ||and more to come!
Metal381 Offline
I have used motorcraft parts and they are new not remanufactured. That is why i do not understand this problem. As long as the car is warmed up the problem will not occur. Anyone think it might be the engine temp sensor? I appreciate any ideas this is really annoying me. Thanks guys!
I am thinking ECT problems. With the motor cold, pull the connector off the ECT and measure its resistance. With coolant at 50 deg, resistance should be about 58,000 ohms. If it is significantly lower than this, replace the ECT.
segfaultxr7 Offline
My original TFI caused a bad miss at ~3000 RPM. I replaced it with a non-Motorcraft TFI, which caused the exact same problem as you're experiencing. Put a new Motorcraft in, it wouldn't advance the timing (very sluggish until 3000 rpm) and then died the next day. Got another one, and it's been good for the past year. I'm kind of leaning toward the ECT, but don't totally discount the TFI just because it's new.
88 TC 5-speed
Metal381 Offline
Well i just got done replacing the ECT. It isnt the problem. I put a brand new one in and it is the same problem as before. Im gonna go and try to buy a new motorcraft tfi module. I cant see it being anything else. Im open to suggestions but tommorow i will be buying the tfi and tryin that out. Thanks guys
If you like spending money and not fixing the problem then please don't:
Metal381 Offline
Well i ran the codes today at my mechanics shop. We got a code 81 after the car was warmed up. It said something about a thermactor or bypass check circuit. I dont have a clue what this is or where the thermactor is. anybody with any info id appreciate. Thanks
