Shadow
Nov 2011
Malaga, NJ
alright.. got my RR in today and new plugs.. but note, this problem was occuring BEFORE the cam swap and tune-up..
i start the car and it idles really rough for a few minutes until it warms up a little.. once it runs smooth, i rev it and it'll either idle rough before picking the RPMs back up and run smooth again, OR it'll idle rough around 500RPMs and die out in 3 seconds or less.. when idling smooth, the tach reads around 1300-1500.. after it dies, it's a bit of a b*tch to get started again..
any ideas? i did a compression test before putting the new plugs in and the numbers were between 120-125 across the board
3 87 TC's, only 1 4 banger
R.I.P. Joe Zumpano 8/29/86 - 11/11/11
Have you pulled the codes?
Shadow
Nov 2011
Malaga, NJ
no codes, other than the 1 for the ECT which is currently unplugged
Try putting in a good ECT.
Shadow
Nov 2011
Malaga, NJ
it was doing it, even when the ECT was working properly.. it just got unplugged last night, as it quit working last week while i had it running to keep the battery charged.. it's been acting this way since i got the car, but i figured it may have had something to do with the cam or garbage plugs/wires, since it idled like garbage until they were replaced
No offense intended but how do you know the ECT died last week. They don't set a code until they are dead, but they can cause a lot of havoc as they are going bad and still won't set a code. It is not an insignificant sensor
Shadow
Nov 2011
Malaga, NJ
well, it went completely KAPUT last week.. was working to what i assume was 'fine' until it died and killed the fan.. ordered a new 1 from rockauto yesterday, should have it by saturday
Shadow
Nov 2011
Malaga, NJ
alright! NOW i have codes..
23.. TPS voltage
51.. ECT
83.. EGR, fan control circuit or low speed fuel pump relay circuit open
23 - i'll replace the TPS and adjust according
51 - i unplugged it, because it's obviously bad.. replacement already on it's way
83 - i'm guessing it's the EGR or low speed FP relay.. wouldn't the fan not work, even with the ECT unplugged, if the control circuit had issues?
code 83 in TCs relates to the cooling fans
For help see http://www.tbirdheritage.com/turbocoupe/...-Chart.php
Shadow
Nov 2011
Malaga, NJ
you think that it could be the fact that the ECT is unplugged, or there's another issue with the actual controller circuit?
