Hey Guys,
thought I might share with you some pics of my awesome gauge I'm building It replaces the panel with the 12V outlet in the dash. I relocated the 12 V outlet to the console and put it in the ash tray area, I also added a couple modern goodies to it to make it more functional. The nice thing is the lid still closes so when I don't need it Its hidden.
For the Electronic gauge I used an arduino to interpret the signals from some sensors I installed. At the moment I only have 4 sensors so I dont have all the sensors in that are displayed on the lcd. Hopefully by next weekend I will have it all in an functional. I think it looks rather good.
Here's some pics of the lcd display panel and the relocated 12 v outlet.
https://plus.google.com/u/0/photos/10174...9664334626
https://plus.google.com/u/0/photos/10174...7292312162
https://plus.google.com/u/0/photos/10174...2922804450
https://plus.google.com/u/0/photos/10174...2160592626
^ This is awesome!
P.S. The lcd display is awesome too! Very nice work!
Martin
Aug 2001
Agassiz, BC, Canada
Nice! Can you do Larger type for us Old Eyes Guys!
Boost High, Fly Low
Yes I hope so, I want to make it so it only shows 2 readings at once, but the coding is apparently hard to do it that way. First I will make it work as is then experiment with doubling the font size.
zip
Dec 2006
Modesto, CA
Nice! Ive been thinking of doing something like this with an extra Uno I have sitting around. Which MAP sensor are you using for the boost reference? I'm also curious as to what the pot will be used for, brightness of the display?
Matt
Very nice accomplishment!
^^^^ +1 Super cool!
Not B Anymore
Nokesville, VA, USA
This makes my volt meter install look pointless and stupid. Hahaha!
Nice work, man!
RC Martin
Mar 2006
Colorado
Can you list the parts that you used for the project? I'm curious about the display and the sending units you are using. Gives me an idea of something very similar, but in the factory clock/tripminder location...
Hey guys sorry for the lack of replies, I have a couple days left of grade 12 before I'm all done with high school so I need to make sure I finish them up well. I will post a list and some pics of what I used to put it all together once I get it working right, hopefully in less then 2 weeks.
Just a quick question for those electrically inclinend people, will the voltage in my 83 tc ever spike above say max 20 volts? I am taking power from the circuit that supplies power to the power antenna.
Thanks,
Matt
