i THINK i scored a T3
BJL Offline
Moderator
wel buddy of mien was cleanign out his firend garage (her husband left her with a garage frul of junk a few years back)
this is also the kid that got me a set of groun effects for a 83-86 TC that i cant use.
ok back to the turbo, there was one layign around, loosk to be T3 ish, says air research on it, same bolt p[attern exhuast inlet, big oil return like my 83 TC. its has lots fo shaft play,b ut i plan on gettign a rebuild kit if this works, but my question is, that the front of the turbo doest have a flang like my IHI, is has a round connection for lieka rubber hose, loosk to be 2 1/4 -2 1/2, cant relaly determins size that well. but it also has a external waste gate, is this a T3? its off a Saab i bleive, thanks!
BTW it was freee so no lose if its not!
Brian Larkin
88TC 330,000 miles
Slightly Modified
BJL Offline
Moderator
it has engravins ont he inlet saying
" RC. M10 AIR .42"
then on the back near the waste gate it says "DH4/4 garrett H4"
hope this helps
Steve says that the saabs used a .42 compressor housing, and this thing is oil cooled, so i dont think its a usable one for me, but no lose, it was free
Brian Larkin
88TC 330,000 miles
Slightly Modified
Noname
Unregistered
Now THERE'S a reliable source.
turbocoupe88 Offline
Sorry to go off topic but let me know if you want to sell them ground effects, I just bought an 85 TC. I live right outside Philly.
1985.5 Turbocoupe
Previous- 1988 Turbocoupe
http://www.geocities.com/boosted4d/1985Turbocoupe.html
rpratt Offline
" RC. M10 AIR .42"
hope this helps
with your typing skills, I'm sure someone will come up with what that is...within one letter/number of it anyway.
Glenn 88TC Offline
If it is a Saab turbo it is fairly small as far as a t3 goes. Not much bigger than an ihi. I wouldn't bother rebuilding it. I would sell it and put that money towards a .60/.63 t3 or better yet a t3/t4.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, TE60 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Hallman boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
BJL Offline
Moderator
DAMN! no fair, grrrr, yea it loosk small, i gues sil spend the money on that 83 TC motor once i yank it out of that rusy body.
Turbocoupe88
the body kit only has the fornt valance and side skirts, i didnt get a rear skirt with it, so emial me at [email protected] if your stil intrested,
the kit needs some plastic work dmne to it, its not perfect.
Brian J Larkin AKA Turbo
1988 Turbo Coupe 5spd
Twilight Blue
boost valve, k&n cone, glasspacks gettto rigged ram air, cracked header panel
http://natoubb.turboford.org/uploads/BJL/burnout3-9.jpg
Brian Larkin
88TC 330,000 miles
Slightly Modified
