COOKER
Jan 2002
Canton, Ohio USA
I unhooked the battery for about 30 min and started it up got it warm then pulled the codes 11 does this mean everything is a okay????????
I REALLY HOPE SO GAS MILAGE WAS SUCKING HOPE THIS WILL SOLVE THE PROBLEM...
ONE MORE ?? HOW MUCH GAS IS IN THE TANK WHEN THE GAS LIGHT COMES ON?? JUST CURIOUS.
DAVE COOK
NEED MY TC BACK
11 is the code for OK, Did you get an 11 for each of the 3 parts of the test? Clearing the codes is not going to change anything if it was running rich.
Walsted
Fort Worth, TX
Quote:Originally posted by COOKER:
...How much gas is in the tank when the gas light comes on?...
I don't know the specific value, but from what I can tell from the 1986 EVTM, it is going to have quite a bit of variance since it gets its data from the same circuit as the fuel gauge, IVR and all. So, it will come on at the same spot on the fuel gauge each time.
Mike Walsted - NATO member
1986 5-speed TurboCoupe .
BJL
Williamstown, New Jersey
My gas light comes on at about 1/8 of a tank and im usually at around 300 milees on that tank by then, meaning i have about 40miles till it hits the E mark on the gauge and about 50 miles after that til it runs out of gas
Brian J Larkin
1988 Turbo Coupe 5spd, dark blue and shining like a peice of polished glass. http://crazydriver358.5u.com
[This message has been edited by BJL (edited 03-17-2002).]
Brian Larkin
88TC 330,000 miles
Slightly Modified
segfaultxr7
Aug 2001
Cape Coral, FL
Might be time for a tune-up. I changed my plugs and wires (after all of 10k miles), that restored a LOT of power and gas mileage went from about 16mpg to 18.5 in town. These cars have freakishly sensitive ignition systems.
88 TC 5-speed
