Ive been through this board, Turbo Ford and even Foxtbird cougars looking for a solution to my problem, but no dice. Here we go:
1988 TC manual, Cone on the VAM, Gillis at 18, FRESH Motorcraft Tuneup (Plugs, Wires, Cap,Rotor,) New ECT Sensor. Fuel Pressure is correct at Idle, and at cruise/under boost. TPS is set to .94V, IAC is a NOS Motorcraft part. Timing (Ignition) Is dead on at 10* Spout out. Cam Timing hasnt been verified. Pulled codes, Memory code 42 is the only one Ive EVER come up with. Fresh motorcraft Ignition coil.
Okay here's the problem. When I first start it up in the morning, or afternoon (Engine Cold) It misses a bit for about 20-30 seconds and catches correct, Idles up a bit till it gets warm, and the idle settles back to 1000rpms. Now, the car can be completely warm, or just barely warm, and I will have varying vac readings at idle. sometimes I look and it will be at 15-16, sometimes 18-19. It doesnt fluctuate quickly at all, and Ive never actually caught it moving one way or the other. At Idle I get a strong miss for a split second at least once or twice every minute or so. It seems like the ignition is cutting out, but I havnt been able to fuiger out if that is the case. At WOT it misses a bit, not much but enough to notice a lack of power for a sec. It also looses Most of its power at full boost and about 4K RPMs. It drives around town fine, but everysooften, I seem to catch it miss VERY VERY slightly, so slight in fact I question if its really happening. Like I said, the ony code is a memory code 42, and it seems to come back up every so often after i clear the codes. FPR hose is dry, no fuel inside, just the very slight smell. The injectors are also sealed tight with no leaks, and all have been professionaly cleaned in the last 6 months. Could it be possible that the cam timing is off one tooth and cause this?? I'm only getting between 17 and 21MPG lately also. I'm just sick of the miss.
My 87TC seemed to pull a lot harder with just a cone and a bypassed BCS. And that motor had 278K on the clock as opposed to under 100K like this one does. any help would be apreciated.
All hail Project "Marauder" !
