ridgeback
Feb 2002
Milford,CT
what are my options for an aftermarket "Timing Mark Pointer" ?
I have my engine all back together and don't want to use the ugly and cracked Plastic Front & back Belt cover that holds the timing marks. I need a solution asap please!!!
thanks,
Ron
Ron
Black 87 TC, 2nd owner since [email protected], [email protected]
Not B Anymore
Nokesville, VA, USA
ridgeback
Feb 2002
Milford,CT
I actually am very impatient I guess cause I just order that before your post but thanks for the reply. I couldn't find anything else on the web so I just went ahead and bought that one.
Thanks
Ron
Not B Anymore
Nokesville, VA, USA
It's a nice piece. I have one on the '86.
ridgeback
Feb 2002
Milford,CT
was it an easy bolt on... all parts supplied?
will it go on without pulley removal?
Ron
Not B Anymore
Nokesville, VA, USA
I thought it was quite easy, but I already had the front of the engine apart. Yes you need to remove the crank pulley to get one of the bolts on. It is adjustable, but I didn't have to adjust mine when I put it on.
